#116382
So I'm thinking of replacing my Blaupunkt Bamberg (uses the stock 928 audio harness with DIN to the Fosgate amp) with a slightly newer Wiesbaden which uses the more modern Blaupunkt plugs.
Speakers are not an issue as I will run RCA cables to the amp, but is there a socket that can fit the older style power/ground/antenna/light harness on the 86 928S?
Thanks!
Chris
If these folks don't have what you need they can probably supply the components for you to DIY the adapter you need:
https://www.bergvillfx.com/categories/wiring-harnesses
if you still have the original radio connector on the cars wiring loom you need Porsche's adaptor loom 91164240000 to fit onto all modern radio's.
Nothing important, but it struck me this morning[…]
:thumbup: :rockon: :burnout:
