- Tue Nov 16, 2021 9:08 am
#116382
So I'm thinking of replacing my Blaupunkt Bamberg (uses the stock 928 audio harness with DIN to the Fosgate amp) with a slightly newer Wiesbaden which uses the more modern Blaupunkt plugs.
Speakers are not an issue as I will run RCA cables to the amp, but is there a socket that can fit the older style power/ground/antenna/light harness on the 86 928S?
Thanks!
Chris
Thanks!
Chris
