all from 87+ model year, found in a spare box of parts i have.
By Addlight
#115665
4. Those look like shims, but not sure for what. See if there is anything obvious the holes line up with, such as the hinges for the hood.
thanks Sean, in the same box were the parts below, are they also from a sunroof?
the 3 spacers/shims are steel and are 1.7mm thick, so not bendable, if that helps anybody.
By Addlight
#115694
Those are the sunroof guides, driver and passenger side. Pins on the guides on the cable ends slot into the grooves and as the sunroof opens and closes, the pin slides in the guide to raise or lower the roof to/from roof level. It's part 14 in the diagram.
Addlight wrote:Those are the sunroof guides, driver and passenger side. Pins on the guides on the cable ends slot into the grooves and as the sunroof opens and closes, the pin slides in the guide to raise or lower the roof to/from roof level. It's part 14 in the diagram.
perfect, thanks very much, will stick them on ebay as mine don't have sunroof's
#115701
The shims 'might' be for hood adjustment. Check the distance between bolts on those hinges that fasten to the hood and to the fender.
Correction below by Phil indicates I erred. Not the first time, and I can assure all it won't be the last!!! Good catch Phil.
Gary Knox wrote:The shims 'might' be for hood adjustment. Check the distance between bolts on those hinges that fasten to the hood and to the fender.
pictured are the adjustment shims for the hood hinge.
the hole size in my strips of metal are 6mm, for a 10mm spanner size bolt head.
will keep looking through a PET to see if i spot something that looks like it.
the black strips of metal, last picture on my first post are what Porsche call "desk pads" 92851227700, to shim the rear spoiler 87-95.
#121629
h2pmr wrote: Sat Dec 11, 2021 7:32 am the black strips of metal, last picture on my first post are what Porsche call "desk pads" 92851227700, to shim the rear spoiler 87-95.
Nope, the ones for the wing are notched to fit the contours of the hatch underneath.
:bigcry: , as my school report said, must try harder...
stripping this red S4 and actually found what these are:
PET page 105-06, used to give extra strength to the 4 mounting bolts of the air flap housing, but just not shown on PET
sad the things that can stick in the mind
anybody know what it is ?
Nah, Phil wouldn’t do that.
RHD-only maybe.
thats a very good point Dave, its from the 90 S4 i have just broken, so i should remember where it cam from :hiding:
now thinking about it it might be something to do with the throttle pedal, but thats a guess, need to check my other S4.
h2pmr wrote: Tue Apr 09, 2024 1:59 am thats a very good point Dave, its from the 90 S4 i have just broken, so i should remember where it cam from :hiding:
Hmmm… it did look vaguely familiar. I will check pictures of the shell-out resto.
I screwed up!!@#$$$@@!!
So, I was coming home from a restaurant on the sou[…]
Just got myself a Cayenne
Looks like Graphite Grey.
