By Addlight
#115665
By Addlight
#115694
#115701
#121629
anybody know what it is ?
Nah, Phil wouldn’t do that.
RHD-only maybe.
thats a very good point Dave, its from the 90 S4 i have just broken, so i should remember where it cam from :hiding:
now thinking about it it might be something to do with the throttle pedal, but thats a guess, need to check my other S4.
h2pmr wrote: Tue Apr 09, 2024 1:59 am thats a very good point Dave, its from the 90 S4 i have just broken, so i should remember where it cam from :hiding:
Hmmm… it did look vaguely familiar. I will check pictures of the shell-out resto.
Funny Reply from Ebay seller
Wow, that person is special.
Guess the Job
928s For Sale Thread
