Feed from Classified ads or post your "Wanted" here
By David993S
#9698
1991 Alfa Romeo Spider Veloce. $14,950/OBO
Red/Tan with rare Automatic transmission. 2.0 litre, double overhead cam. Currently has 21,3xx original miles. Selling because I just don't drive it except to the occasional show. I've owned this pretty Alfa since October 2008. Since purchasing the car with just under 19,000 miles (currently 21,xxx miles), I've performed the following documented work:
rebuild drive shaft (mounts, bearing, u-joints)
replaced fuel pump and cooling fan relays
alignment
replace freeze plug
replace spark plugs (due to freeze plug leak wetting #2 spark plug)
full tune up
replace mass air flow boot
replace fuel filter
replace fuel pump
cooling system flush
new left and right front brake calipers
new front & rear brake pads
brake fluid flush
new engine mounts
4 new Sumitomo HTR H4 tires
4 new Rota "minilite" wheels
new Dash Cover cap (Vick's Autosports)
multiple oil/filter changes even though it's rarely driven
This Alfa runs and shows well, and includes the hard-to-find top boot cover in tan. But no '91 Alfa Spider is perfect............ Paint is 9/10 with a small door ding behind driver's door (tried to show it in the photo), and the clear coat has lifted off the 3rd brake light cover and in a small area on the cowling. The AC needs recharging. Probably some other minor items, but hey - it's a 29 year old Alfa.
SeanR, sithot liked this
By Streck-Fu
#11275
I really wish I was in the market. I'd love to buy this. Especially semi-local.
Great looking car.
IMI starter PSA
I spent endless hours with IMA 15 years ago to mak[…]
https://i.gyazo.com/76c914399cb17e00d106f4e0d7111[…]
Folks arriving. https://i.gyazo.com/b2a54539f299[…]
My friend's Aventurine Green 968 is up for auction[…]
