By Scott at Team Harco
#112688
I prefer the night format. But, when I click on "Board Index", it goes to daylight format. And I can't tell which sections of the Porsche section I have previously read (no color difference).
Not a huge deal, just not what I would prefer.
Scott at Team Harco wrote: Thu Oct 28, 2021 2:33 pm I prefer the night format. But, when I click on "Board Index", it goes to daylight format. And I can't tell which sections of the Porsche section I have previously read (no color difference).
It's not supposed to do that. Once you select that style it should stay that way. Let me look into it!
#112701
fpena944 wrote: Thu Oct 28, 2021 3:04 pm @Scott at Team Harco - try it now. It was doing the same for me but I think I fixed it as it's persistent now as it should be when I tested it.
Nope. Still the same.
Scott at Team Harco wrote: Thu Oct 28, 2021 3:08 pm
Can you try logging out and back in?
#112713
fpena944 wrote: Thu Oct 28, 2021 3:18 pm
Two times. Still not right. When I first open the site, it is dark. When I click on Board Index, it goes bright.
By AKSteve
#112718
You're actually switching to a whole other user. Look at your name when the screen switched to Daytime. Currently the board switches everyone to username: Designer. But when you go back a forum, you switch back to yourself (and Night Mode).
AKSteve wrote: Thu Oct 28, 2021 3:58 pm You're actually switching to a whole other user. Look at your name when the screen switched to Daytime. Currently the board switches everyone to username: Designer. But when you go back a forum, you switch back to yourself (and Night Mode).
Yeah it was happening because of the same issue from yesterday/this morning. But I believe I disabled it permanently now so it should be good going forward. The problem is browsers have their own cache too so you might have to clear the Open Road cookie for it to get back to the right status.
I've been browsing for a while now and since making the change haven't had any strange issues on mobile or desktop.
But let me know if even after cleaning cookies it still happens.
sunroof cover questions
928 quick questions thread
