By ChrisZ - Wed Jul 22, 2026 6:10 pm
#347998
So my AC lines from the compressor are garbage and leaking and need replacement. The high pressure line was sort of easy to get apart, but the low pressure line from the AC compressor to the hard line is a problem.
It's easy enough to get the compressor dropped and the 1 1/8 nut off the compressor, but the hard line is a different story: I can get a 1 1/4 wrench on the nut with no problem from the top, but there seems to be no way to support the line behind it which also seems to have the low pressure AC port on the nut.
And I know if I try to turn it the hard line will rip apart and I'll be looking at an engine pull.
Can't go from the top as there is a hard line to the radiator above it, can't go from the bottom as there is a smog pump filter canister in the way. Any ideas?
1986.5 928S Prussian Blue, daily driver
1997 944S Crimson, owned 30+ years now
2000 Honda Insight (the "Not Porsche")
