By linderpat - Wed Oct 18, 2023 7:44 am
#239064
What a PIA it was to get the dust boots on, and the pistons back in the cylinders. I've done this before on other cars, and none were like this. I needed C clamp to slowly work the pistons back in. The trick with the dust boots is to put them on the piston, pull down allowing the lip just below the bottom of the piston, then get the lip into the caliper groove first. With the lube, that is very tricky. Then you would think you could just push the piston in with your hands, no such luck. Anyway, got it all together after much struggle.
Out here in the perimeter we is stoned, immaculate.
