linderpat wrote: ↑Sat Sep 02, 2023 3:54 pm
worf wrote: ↑Thu Aug 31, 2023 3:41 pm
If the above is not true the problem is the reverse switch or the stub harness that exits the spare tire well and goes to the switch on the transaxle.
This is what I found - no continuity with trans in reverse or not in reverse. So a new switch is likely to rectify.
Ok. So, first are you 100% certain that your test methodology was correct? You verified that the meter would register continuity on itself or some other wire? I always do this just to be certain. Right wires tested? On the correct connector?
Double-checking ‘cause the next steps are more involved.
You’ll need to get it up in the air. Liftbars, etc.
The switch is on the forward-left side of the transaxle. It’s the only electrical-looking think on the left side.
The harness end doesn’t have a plug for the switch. It’s just two pins soldered to the wires that plug into the switch: Don’t yank on it or you’ll break the wire at the solder joints to the pins. Instead…
Carefully, gently, pull back the dust boot on the switch and with some small needle-nose pliers, or big tweezers, etc., wiggle out each of the two pins from the switch.
At that point check continuity of each wire from the pin, back to the connector in the spare tire well. If you’ve got continuity then it probably is the switch (might still be intermittent wiring issues or just oxidation of pins) so, do my first-described test again but directly at the switch.
The Reddit Conjecture: Sufficiently advanced stupidity is indistinguishable from malice.
Worf’s Identity: Sufficiently advanced laziness is indistinguishable from stupidity
Worf's Law: Once you've mitigated risk from stupidity and laziness in your endeavors, failure is usually the result of insufficient imagination.
My 928 Inspection Guide
