- Thu Apr 20, 2023 4:44 pm
#211489
Since driving the car again and the ambient temperatures have been in the 70's or 80's I've noticed the engine temps were getting a little higher than I remembered. With the engine fully warmed up while driving the needle was always a little above the middle white line. But, in stop and go traffic and slow speeds it was increasing to just below the top white line. Never in the red. But, then again the most the outside temps were, were in the mid 80's. Higher temps are coming.
Checked the spin resistance of the fan compared to Ed's and found my fan was spinning pretty easily. I must have lost fluid in there.
Using these write up from Wally P and a thread on RL by Chris (Landseer) as guidelines and went ahead and started the rehab.
http://www.nichols.nu/tip482.htm
https://rennlist.com/forums/928-forum/5 ... -fill.html
This is what I bought from a local RC/Hobby store.
Cost about $10 each for the 10k CST bottles and $5 for the bottle with a metal, needle like tip.
After taking off the bimetallic cover, little metal pin and gasket cover, I heated the out edge of the clutch and started squeezing the silicone into the fill hole. Spinning the fan, squeezing more in...Heated, spinning and squeezing over and over. Probably over a couple hours for sure. Spinning the fan in the horizontal position as it was clamped to my table, it didn't seem like the resistance was getting any where.
Finally after getting 3/4 of the 2 oz bottle in, no more would seem to suck in.
I cleaned the little metal pin with 600 grit sand paper and put it back in with gasket cover. Put a dab of RTV on the top of the pin (Per Stan's suggestion)
Put the Bimettallic cover back on and applied more RTV to sides to hold it in place.
After I turned it over in the correct vertical position, the spin resistance was much much better.
Haven't tried driving yet. But, I feel this was a success. We'll see and I'll report back
Thanks
Rick
1985 Schwarz/Burgundy / 5-speed /X-Pipe and no Cats
"Porken S300s Chips, Dips, Chains and Whips. You know, your basic HS orgy type things" - Lisa (Weird Science)
Rick
