I’ve never used red before. I traditionally use blue and torque to 218 foot pounds.
I had the pulley work loose during a dyno session today. Embarrassing, but luckily no damage to the treads on the crank.
Bad news is this is the huge 928 Motorsports pulley so I had to push the car off and pull the radiator to re-torque with red. Long day.
Well, not sure what was the problem. But, given “928 Motorsports”… that’d be my bet.
Washer backwards?
If not those then torque procedure perhaps?
I have a 3/4” snap-on y-beam torque wrench. I’ve never had a crank bolt come loose including the Twin-Screw.
One thing’s for certain: you’ll need to remember to heat that crank bolt before you attempt to remove it next time.
I don’t know. It does not give me a warm fuzzy that’s for sure. The pulley it supposed to be balanced, but honestly I never tested it. If it’s unbalanced you can’t see it with the naked eye.
The belt set up is reasonable, stock PS and alt to driver side and supercharger is a 6pk to passenger side.
Here’s the numbers for what it’s worth, before the fun began:
Roughly 425 bhp, 465 ft-lbs at the crank assuming 15% driveline loss.
Not shabby!
Nice torque curve too.
you shouldn't need loctite if you have a new bolt and torque to spec. I spun out the crank bolt on my fast revving stroker engine several times, and replaced with a new bolt and didn't have a problem again The longer supercharger pulley is going to amplify the stresses of the bolt and thread and a new bolt should have been used anyway. Did the kit specify loctite? what do the murf kits require?
#210338
Red is permanent - I don't think that was a good idea. Hopefully, the threads were not completely free of grease or oil.
Thanks Dave, I was pleased with the torque but I guess my hp goal was a little higher. I wanted to be able to say 400 hp at the wheels, but I will take it.
Sterling, Long story but I didn’t buy Carl’s kit, just the pulley. No sexual favors were required but you can imagine the conversation;)
I never saw his “directions”, I think you only got them if you bought the kit.
The bolt was new FWIW.
Geza, yeah I get it. That’s why I never used it before.
But, looking at the carnival yesterday it seemed the best way to get home. I have talked to people that have used it and say no issues, with heat of course.
Crumpler wrote: Thu Apr 13, 2023 2:22 pm Thanks Dave, I was pleased with the torque but I guess my hp goal was a little higher. I wanted to be able to say 400 hp at the wheels, but I will take it.
Horsepower sells cars. Torque wins races.
If you want more horsepower, you’ll have to figure out how to extend the torque plateau higher into the rev band. I don’t have a clue if your SC is the limitation or the intake or the throttle body. I’m assuming with that, that more air is required. But…
What’s the fuel-air ratio when the torque begins to drop.
Lol. Just don’t type that name again in this thread and we’re all good.
955 TTS engine replacement
upload some pics when i'ts home so we don't have t[…]
we need pitchers
The DIY thread
I had to replace the windshield washer filler neck[…]
Assuming this got resolved? I've just been li[…]
