- Thu May 18, 2023 3:57 pm
#216324
Got this code on my 2011 Cayenne Turbo and unfortunately there seems to be very little about this code and how to fix it available online.
No symptoms on the car except for the check engine light being lit. I cleared it a couple of times but it pops back up pretty quickly.
Now this is where I'm confused. At first I was thinking maybe I need to replace the thermostat, but when I look at that there is no electrical connection on the unit so if there is a "heater" it doesn't appear to have any wiring associated with it.
My father was doing some diagnosing and did find a sensor beneath the intake plenum going into one of the coolant lines that appeared to be corroded and the wiring frayed. But when I go to look for this unknown part within the online parts catalogs I can't find it and not sure if that is the part that might need replacing.
Anyone have any idea what it might be? I'm shocked there is so little information online about it. I found one thread on RennTech but in that case the Cayenne was overheating. In my case it's driving just fine.
Anyone ever seen something like this before?
