- Fri Sep 02, 2022 5:09 pm
#169287
Took a day off of work today and my dad and I just replaced all four corners of rotors and brakes on the CTT.
The wear indicators hadn't gone off yet but the fronts were pretty close to worn and I could feel a little bit of pulsating on the pedal telling me the rotors weren't in great shape either.
All went well and relatively easy but the parking brake is now complaining. My father has a Snap-On professional diagnostic machine from when he had his own shop. On there it has a procedure that backs out the parking brake so that you can replace the rear rotors. Doing so puts the brakes in what is referred to as service mode. So far so good, right?
Well when all is said and done, we put it back together hoping we can just re-calibrate the parking brake and be done with it. Nope, the car expects us to go through a procedure known as "grinding" where you're supposed to put the parking brake on and go up to 12 MPH for 100 feet then release the parking brake. It asks us to do this 8 times!!!
We didn't replace the parking brake shoes as they seemed fine. But if I go through this procedure I'm sure I'll destroy them. So does anyone know a way around this?
The brake still works and I drove the car home without issues but the "Parking Brake in Service Mode" message won't go away and won't reset itself unless we do this horrid procedure. Any alternatives?
