- Tue Dec 13, 2022 12:56 pm
#188389
I have 2 cars where use the vacuum - my Audi A6 (2014) and my Jag F Pace (2017). Both have the oil filter on the top, and neither came with a dip stick. With the Audi, there was a tube for a dip stick, so I pulled the plug off and bought a dip stick, and pull from there with the vacuum. For the Jag, there is no dip stick tub. Instead. pull the filter and suck it up from that point. This is the fastest/cleanest way to change oil, and you do get most of it out. Most oil service shops and dealers now do it this way. Make sure the oil is warm - run the car - all of the particulate will be suspended and will be extracted. On my sports cars with oil filters under the motor, I use the drain plug, since I'd be down there anyway o change the filter.
Out here in the perimeter we is stoned, immaculate.
