Watercooled 911s
By TheDeckMan
#240789
Figured this would be a good place to condense a lot of Manthey info/videos/pictures collected of the 996 platform.
MR Carbon 996 Roof
MR 996 GT2
Manthey Forged Magnesium BBS
MR GT3
MR RSR Body Kit
MR Turbo RSR
fpena944, SeanR, amdavid and 1 others liked this
By TheDeckMan
#241869
I've seen some of Manthey's newer work but haven't run across too much with the 996 platform. Thanks for sharing!
By TheDeckMan
#243741
They really got started with the 996 Cups then 997 Cups for racing, along with modifying street going versions. Norbert Webber worked with Olaf on the MR body kits to improve aerodynamics. The MR setup would beat the factory 996RSR in Porsches wind tunnel with the rounded edges which had much better air management, a lot of this would be carried over to the later 991 RSR which Norbert had a big hand in.
The original MR wide body car used a 996tt engine with the intercoolers moved to the top to protect from the tires/rubbing, the kit also moved a lot of the radiators to push hot air out the side of the car and protect them better than the factory RSRs. The 996 turbo motor ended up being too much power causing excessive tire wear, at which point they built the first of the 4.4L NA motors.
Meeting Nobert and Olaf in person was a hell of an experience along with getting to see the behind workings. The 996/997 MR parts are really becoming very hard to find like the Andial aircooled parts.
fpena944, amdavid liked this
