Page 3 of 3
Re: 997 Forum
Posted: Fri Mar 12, 2021 2:29 pm
by TheDeckMan
Thanks David! Cannot wait to get some good wrenching done in the garage soon.
Re: 997 Forum
Posted: Sun Mar 21, 2021 2:10 pm
by TheDeckMan
Scooped up a new lip for the 997, looks a little more aggressive and for $135 why not?!
old
new
now needs to just be moar low.
Re: 997 Forum
Posted: Fri May 28, 2021 1:26 pm
by linderpat
Happy Friday and Memorial Day weekend folks. this weekend is Pagid's, wheels/tires and hi-temp brake fluid to get track ready for next Friday.
Re: 997 Forum
Posted: Fri May 28, 2021 3:51 pm
by TheDeckMan
Sounds like a fun weekend project! Not too hot to be out in the garage! Headed to Lime Rock to watch the IMSA races.
Re: 997 Forum
Posted: Fri May 28, 2021 5:57 pm
by amdavid
Excellent!
Re: 997 Forum
Posted: Sat Jun 05, 2021 11:15 am
by amdavid
Dug up a pic of the departed 997 that’s now sporting a 4.0l. Yes, I will be back in a 997...waiting for the expanding bubble to pop.
Re: 997 Forum
Posted: Mon Jun 07, 2021 6:02 am
by linderpat
So sick of easy projects becoming disasters! Stripped the hex head caliper bolts on 2 of the calipers this weekend - the front right and the rear left side
The brake job on these cars is ridiculously easy, right up until they are not. So now, because I need to car for a big drive later this week, it has to go to the shop to do the two bad wheels.
I hate allen head bolts. I've had them strip out on the oil pan bolt. The new caliper bolts are torx, tells you something!
Re: 997 Forum
Posted: Thu Jun 10, 2021 4:40 pm
by groovzilla
Just bought this 2006 997 C4 Cabriolet.
Very happy with it. Really nice cruising around with top down.
Bought in San Francisco and drove home 1000 miles to Seattle with top down. WIndscreen really nice optional feature.
This photo taken at winery in Roseburg Or. Wife did some tasting, I did some photos
Re: 997 Forum
Posted: Thu Jun 10, 2021 4:43 pm
by TheDeckMan
They can be a pita, a little Kroil prior and heat the head a little to pass some heat into the threads, this normally will break loose the loctite on them or corrosion in the aluminum housing. That royally sucks
Most of the coolant hoses showed up and o-rings for the motor drop on the 997, still have to chase down a few more. Now I just need to my buddies 996tt wrapped up this weekend and can move onto getting the 997 fixed.
Re: 997 Forum
Posted: Thu Jun 10, 2021 5:16 pm
by Skyhawk172
Re: 997 Forum
Posted: Fri Jun 11, 2021 11:10 pm
by groovzilla
Liking the full leather. But the best aspect are the black faced guages. I don't dig the white.
Black Gauges Matter.
Re: 997 Forum
Posted: Sat Jun 12, 2021 8:58 am
by Scott at Team Harco
The leg must be healing well. I expected to see an automatic transmission shifter.
Re: 997 Forum
Posted: Sun Jun 13, 2021 12:28 pm
by groovzilla
Knee is coming along. Surgery Oct 27th and almost 8 months later I can move the knee well. Only issue is it is still weak and I just am able now to climb steps without holding handrail.
Doctor said full year before it is back to close to new so have to be patient.
All the best.
Re: 997 Forum
Posted: Sat Jul 10, 2021 8:38 pm
by linderpat
it sure is quiet here. Not like the 928 forum, where there is a lot of activity daily. Anyway, looking at my post count (997 on this one) I thought I'd drop that one in here just for giggles. We'll see how long it is before anyone responds
My Motor Fell Out...
Posted: Sun Jul 18, 2021 12:30 pm
by latonnelier
After I put the car on the lift and unclipped/unhooked and unbolted a bunch of stuff. I slid the lift table under the motor with some judiciously placed 2x4s and away she went. Now I start the tedious process of removing all the peripherals and sending the case halves to LN, the heads to Hoffman and wherever I can find for the crank that is reputable--can anyone in the Phoenix area recommend a good machine shop? If everything goes well, she'll be back running in 2-3 months.
The car has had a bit of ticking at startup lately, so I'm interested to see what the cylinders look like under all the dirt that seems to be holding everything together now. I also have to rebuild the starter and maybe I'll put a new regulator on the alternator. Have some new Bilsteins (I bought last year--or was that a year or two before?) and I'll also be replacing a whole bunch of cooling hoses, seems only appropriate for a 198k pcar. For your entertainment, I give you my 2006, C2S; under the knife(or wrench)...
OH, by the way. If anyone has any small parts for the motor they might be looking to sell but didn't want to bother with a classified, let me know and perhaps I can relieve you of your burden:)
Re: 997 Forum
Posted: Sun Jul 18, 2021 5:58 pm
by ranger22
Last Friday, I dropped off Chik-Fil-A to finish the makeover and turn this car into the beast that it deserves to be.
Re: My Motor Fell Out...
Posted: Mon Jul 19, 2021 9:30 am
latonnelier wrote: ↑Sun Jul 18, 2021 12:30 pm
Gary - please start a dedicated thread related to this rebuild. I have a few used parts from my 3.4 rebuild. You are welcome to any you want. There would obviously be risk with any of these parts. I do have a new chain that drives the IMS. If you don't have the internal drive style chain, then this might work for you.
Do you have the Raby DVD set? If not, I know a guy...
Re: 997 Forum
Posted: Mon Jul 19, 2021 11:03 am
by linderpat
yes, let's keep this one as a dedicated thread - would love to follow the updates. Good luck with the rebuild
Re: 997 Forum
Posted: Mon Jul 19, 2021 4:09 pm
by latonnelier
OK you guys: new thread started here
viewtopic.php?f=18&t=3104
Posted: Mon Jul 19, 2021 4:22 pm
by latonnelier
[/quote]
[/quote]
Thanks for the suggestion, moved the thread. I do have the internal tooth kind of chain, not the duplex.
I also don't need the DVD set, I attended Jake's class, pre-covid, and have a special book;)
I may not be as prolific as your EPIC thread, but we should have some fun. I'm already down to the long block and should get things torn apart in a couple of days; I'm also remodeling our utility room at the same time. The boss says I have to make a certain amount of progress or I might wake up dead one of these days. Gotta work on her schedule, not mine:)
Re: 997 Forum
Posted: Mon Aug 02, 2021 3:09 pm
by ranger22
Cam actuators look good, clutch has some wear, but prob only need to add the 4.0 pressure plate. I had some RS4.0 wing end plates CNC’d from aluminum and then worked with Getty Design to made molds. Now anyone can buy a set at a reasonable price instead of the $3800 for OEM plates.
Re: 997 Forum
Posted: Wed Aug 04, 2021 12:35 pm
by latonnelier
Re: 997 Forum
Posted: Thu Aug 12, 2021 3:05 pm
by ranger22
Finally got my car all buttoned up. Looks, sounds and feels a little different now…..
Re: 997 Forum
Posted: Thu Aug 12, 2021 3:39 pm
by TheDeckMan
looks great!
Re: 997 Forum
Posted: Fri Aug 13, 2021 12:59 pm
by linderpat
love that exhaust. I'll bet the sound is awesome.
Re: 997 Forum
Posted: Fri Aug 13, 2021 2:48 pm
by amdavid
Mucho better....yes, would love to hear it.
Re: 997 Forum
Posted: Fri Aug 13, 2021 7:02 pm
by ranger22
Thanks guys! I’ll see about making a video, but videos never seem to do the sound justice.
Is there a way to uplink a video direct to the site? Or do I need to use one of the YouTube/Vimeo places?
Re: 997 Forum
Posted: Thu Aug 19, 2021 10:48 am
by TheDeckMan
Always found uploading to YouTube the easiest or Instagram for short clips.
Fired my 997tt up for the first time in months to move it around the garage, hopefully can chase down the rest of the back ordered hoses and tensioners to be able to overhaul this winter.
Re: 997 Forum
Posted: Fri Aug 20, 2021 12:29 am
by IrishLegend
Glad to see some familiar names in here!
Re: 997 Forum
Posted: Fri Aug 20, 2021 12:06 pm
by Skyhawk172
Well looks like I should have left the 911 home today but it was her turn to go to work. she is my Girl Friday as my office assistance always says.
Re: 997 Forum
Posted: Fri Aug 20, 2021 1:54 pm
by TheDeckMan
Is that paint?
Re: 997 Forum
Posted: Fri Aug 20, 2021 2:15 pm
by amdavid
Yeah, those aren't pits/chips are they??
Re: 997 Forum
Posted: Fri Aug 20, 2021 2:34 pm
by Skyhawk172
Ash from the Caldor fire
Re: 997 Forum
Posted: Tue Aug 24, 2021 2:56 pm
by TheDeckMan
Skyhawk172 wrote: ↑Fri Aug 20, 2021 2:34 pm
Yikes, at least that washes off!
Re: 997 Forum
Posted: Tue Aug 24, 2021 3:38 pm
by Skyhawk172
most of it blew off on the way home
Re: 997 Forum
Posted: Fri Sep 03, 2021 10:16 pm
by ranger22
Took the wife out for a spin, her first ride. Car has no mufflers now, but she didn’t complain. She’s afraid to drive it though!
She’s a keeper.
Re: 997 Forum
Posted: Tue Mar 22, 2022 12:11 am
by JRMaroon
*Double post
Re: 997 Forum
Posted: Tue Mar 22, 2022 12:12 am
by JRMaroon
Sold the prior 997 Turbo in 2016 and have missed it ever since. The last was a Tip, this is a 2008 Six Speed. A few small projects and parts ordered from Pelican to get it dialed in.
Re: 997 Forum
Posted: Tue Mar 22, 2022 7:04 am
by linderpat
nice. I sold my 997 a few weeks back. I think I will miss it a lot. It'll cost me dear if I do - these aren't depreciating anymore
