#263212
Hello All
So, it's always the case that problems come in pairs which makes diagnosis difficult. In the morning, I had 2 topics with the wave runner and in the afternoon 2 topics with the 91 GT.
My battery kept going down. Well, the hatch is not closing properly after I had to replace the latch with an after market latch because the original one cracked. With time for some reason the rubber bumper in the latch (not the stop below) has worn on the edge and this caused intermittant opening. That was on my radar screen, but I started to get eratic interior lighting as well.
Surprise, surprise, both switches were corroded. At first, I heard the relay (?) only clunking on the drivers door switch when actuated in situ. This seemed odd, because no relay clunk on the passenger door and no relay clunk on either doors of the 90 GT, which has the interior lights work correctly. After a while the relay stopped clunking when I depressed the switch drivers side. Then, the passenger side started clunking... This led to dismounting the switches and looking in closed and open positions.
These cars generally have a high build quality but the switch contacts are really not so clever here. Contact seems only across a very small circular rim of the silver mounting bolt to a copper wire crimp. Anyway, what is the procedure used to keep them in good shape? Guess I will tray some Deoxit and sand paper to improve the intermittent connections. Also, any idea why the 91GT makes a definitive relay clunk when the door switches are actuated and the 90GT does not? And, where is the damn relay? I could not find it in the schematics.
Cheers, John
PS: obviously somebody had been in there because the passengers side silver bolt is partially stripped in front... :confused: Wasn't me.
John, the door pin switches 90+, go to the window/sunroof “regulator” which is under the driver’s seat.
#263345
Many thanks, Worf. Yes, I should have remembered that but the schematics seem to call that thing the "central electrics" or some similarly complicated name and it thew me for a loop.
#263376
For a great primer on how to read the Porsche 928 wiring diagrams, go to this site: http://www.moore-fun.net/928-Electrics/ ... rimers.htm
Agree to Alan's terms, then download, save, print, and read this thesis. You will then be able to better understand what wires connect where, and to what.
Gary
linderpat liked this
Gary Knox wrote: Sat Apr 13, 2024 11:29 am For a great primer on how to read the Porsche 928 wiring diagrams, go to this site: http://www.moore-fun.net/928-Electrics/ ... rimers.htm
Gary
That's a great resource. Thanks Gary! :thumbup:
#263524
Gary, Worf, many thanks! I think I must have even been looking at the wrong schematic... LOL
#263853
Gary, been reading a little in the wiring primer. That is a freakin' assume document and will definitely thank Alan for it.
Gary Knox liked this
IMI starter PSA
Good to know.
Front Wiring Harness
I see that Kroon also has the FOE harness. Has a[…]
Still a Max win today, but not like we're used to […]
sunroof cover questions
the padding doubled the thickness of the cover. I[…]
