just picked up the carpet mats i ordered last week from local OPC and was surprised they were in an old style box
then i noticed the date on the old style part number sticker.... :eyepop:
unopened for 33 years until today, and still in perfect condition.
just amazing what they must have stored in their main parts warehouse in Germany.
lupo.sk liked this
can certainly see the impression of the rear mats on the pile of the front one, luckily a quick hoover sorted it out.
tried suggestions on getting the white paint off the seat, but as i feared it took the blue off easier than the white, so got a few variations of bark blue leather dye and mixed them until i had a good match.
second coat on a couple of days ago and it looks better than i had hoped for in the flesh, and am happy with the colour match of the piping compared to the passenger side seat
seat now back in and that's the interior all back together, but still need a blue Porsche key ring
however hard you clean 36yr old front carpets they just look tired, so the nice new over mats make a vast difference to the interior.
That’s really cool. Coming along nicely
i only got 1 key when i bought it so first job was to take some pictures of it just incase i lost it.
then tried to get one cut locally, most said no, some laughed, but 1 company said they knew somebody that cut them.
so gave them the key and a couple of blanks i bought.
3 weeks later they were cut and looked good, got home and tried them, no joy, had a good look at them.
the cuts were right but it was cut as a mirror image to the original :banghead: :banghead:
so after much trying finally got hold of keys4classicss, sent them the pictures and 2 weeks later got 3 new keys that work perfectly :thumbup:
now just needed to get the Silica key to fit into a Porsche key head, i have done it before but its not a job i like doing
lots of masking tape on the blade, a well trued bench grinder, files and small hacksaw and it eventually fitted pretty good.
i got 3 cut just incase i went to far with the bench grinder or snapped it while cutting the middle section out to fit it in the head, but all went according to plan on the first go.
+ new blue key fob.
another small job done :drink:
thought i would get the old girl out of hibernation after its winter sleep, reconnected the battery and after a couple of seconds fired right up and running smoothly :thumbup:
checked the levels and no coolant in the expansion tank....
took about 3L then started it up, put it on a lift and after about 5 mins of ticking over found it coming from the large O ring seal on the bottom of the coolant bridge, i guess due to a combination of old age and the auto box oil that had been circulation in the coolant.
at least its not the new radiator, but still need to get all the seals etc and just hope the hex bolts hat hold the bridge on are not seized in.
a job for a couple of weeks time.
i knew it had a water leak in the trunk area and i assumed it was just the tail gate seal, but i noticed last month that when i opened the tailgate water dripped out of the interior light on the bottom of the tailgate.
so have just stripped the tailgate and getting our windscreen guy to removed and re bond the tailgate glass and a good tome to re bond all the screws that hold the black trim on.
also a good time to straighten the large trim panel the sun visors bolt to as its a little warped, if it works well will do a thread on how i did it
just 3 questions
when i removed the black trim from around the glass, there are some spacer shims that must alight the glass in the tailgate, how many should there be? where should they be fitted ?and do they have a part number ?as i cannot see them on PET
pictures of the spacer things, i have 3 of them, 2 at the bottom of the screen and 1 at the top.
should there be any on the sides?
h2pmr wrote: Sun May 05, 2024 5:47 am pictures of the spacer things, i have 3 of them, 2 at the bottom of the screen and 1 at the top.
Below is the PET page. I’ve done this once. I recall that PET is mostly right. You’ll want to count the bits and types you have.
JIC you don’t know, and for lookers on… When you do this:
- have shims prepared and tested with the OE glass before removal.
- use shims to align / center new glass
- screw in all thse plastic clamps while the bonding agent for the glass is still soft. (Assuming modern urethane-based materials.)
If you don’t do that last step, you’ll be @#$%ed. The original butyl never hardened so screwing in the clips and installing the trim just moved the glass. With the modern urethane once it hardens the glass will not move, the clips might actually stress the glass and lead to a fracture, and the trim will not be aligned.
Thus, needs to be done while the stuff is soft.
h2pmr wrote: Sun May 05, 2024 5:47 am should there be any on the sides?
Yes. Look for the (empty?) screw holes.
What model year?
worf wrote: Sun May 05, 2024 11:20 am
What model year?
many thanks Dave, its for the 87 S4.
pet shows up to 89 model with integrated rear spoiler, but i guess that should be for the up to 86 model year?
so seal number 15 goes on the screw head on the inside of the tailgate or between trim and tailgate on the outside?
certainly no seals on it at the moment just a lot of instant gasket
will check it over tomorrow and get enough of everything, as want to get it to fit right the first time
h2pmr wrote: Sun May 05, 2024 12:26 pm many thanks Dave, its for the 87 S4.
The one I did was a ‘90. No idea what PET’s talkin’about. The replacement clips I ordered were different - but functionally identical - to those I removed.
h2pmr wrote: Sun May 05, 2024 12:26 pm so seal number 15 goes on the screw head on the inside of the tailgate or between trim and tailgate on the outside?
The seal goes inside, on the screw flange. I ordered the seals. And then lost them in between receipt and the months before use . :kickbutt: However, I noted that the seals are basically die-cut strip caulk. So, if you have 3M strip caulk you can just make your own.
h2pmr wrote: Sun May 05, 2024 12:26 pm will check it over tomorrow and get enough of everything, as want to get it to fit right the first time
I’m pretty sure that there are more than 8 and less than 19. So, get it all cleaned up and count holes.
had a look at it this morning Dave, and when i had removed the black trim around the glass all the spacers had come out with the trim and i just thought they were part of the trim :kickbutt:
so there are 27 holes and thus 27 spacers, 19 +8 on PET does make the 27
the black trim around the glass has little cut outs so the spacers can only fit at a specific place on the trim an so line up with the holes.
but as pictured the spacer that fits in the middle at the bottom behind the 928 logo has nothing to clip into on the trim so is purely a spacer to roughly align the glass i guess
there is also an extra groove in the trim at the top for a spacer but no hole.
as well as having the caulk seals on the inside screw washers there are also very small caulk seals between the spacers and the tailgate on this car
i guess they were trying different options on this early 87
Guess the Job
… the window would not operate when the door wa[…]
Honda ACTY (Kei Truck)
No news yet on the Acty since we don't get our fun[…]
The car is back on the road! :)
Pretty Good Weekend for Porsche
Yeah, Penske is pretty amazing. Love seeing Porsch[…]
