Copper washers for oil cooler block fittings.
Posted: Fri Aug 19, 2022 7:02 pm
Are copper washers ok to use under the block oil cooler fittings. I have some at hand if not I can get the standard ones. I am replacing my oil cooler hoses and one fitting let go and yes chipped the thread a bit. JB weld time. I actually have both off as I was thinking about going to AN fittings but changed my mind. Hoses are in being replaced.
