By sh944
#203192
Ready to come home… should have it in the garage on Saturday.
amdavid, XR4Tim, shadetree liked this
So... I guess this is what happens if you don't use a flare wrench on pipe fittings?
The entire nut is twisted like a helix.
Can someone with more talent for breaking things explain how this happens?
worf wrote: Thu Mar 02, 2023 6:04 pm So... I guess this is what happens if you don't use a flare wrench on pipe fittings?
I break things.
No idea. Copious heat and wrong wrench?
worf wrote:So... I guess this is what happens if you don't use a flare wrench on pipe fittings?
none metric sized spanner.
but did you get it unscrewed ok?
Crumpler wrote: Sat Mar 04, 2023 2:22 pm No idea. Copious heat and wrong wrench?
That's the fitting for the high-pressure output of the receiver/dryer. If you "torched" it, you'd melt/burn a bunch of stuff and although there are a ton of "idiot tricks" on this S4, so far, I haven't found anything melted by a torch.
h2pmr wrote: Sat Mar 04, 2023 3:21 pm none metric sized spanner.
Hmmm.... that's as good a theory as any.
h2pmr wrote: Sat Mar 04, 2023 3:21 pm but did you get it unscrewed ok?
I did.
Luckily, I have an old H/P A/C hose I can use as a core 'cause that (above-pictured) hose is going in the trash. Maybe I can find replacement fittings.
I do have to take you to task for your picture. You're supposed to post a picture that's 928-related and I can't find a 928 in your picture :evilgrin: :beerchug:
The more disassembly I do on 'the winter car' the more I want to burn down the shop that did most of the work on it in the last 15 years. At this point I'm so used to finding incompetent, sloppy, lazy, or thoughtless work that it doesn't register enough anymore for me to get irate about. But, this shop has done things that just seem like they were screwing things up so as to make extra work the next time they saw it. I have literally never seen such butchery as on this one.
Here's one example: At what point are you doing the client a disservice by not replacing lug nuts? The answer is "two or three removal/install cycles before this:"
9 of 10 lug nuts on the front were like that -^ one.
By sh944
#205377
First decent cleaning of Lisa's car after we got it home...
hernanca, XR4Tim, shadetree liked this
making life easier
probably only of use to us guy's on this side of the pond, but the twin filament bulb holder on the rear lamp of an 87+ that can corrode the terminals and fail can be replaced with a Peugeot 108 or Citroen C1 MK2 rear lamp bulb holder.
just need to remove an extra securing lug and it fits and seal like a glove :thumbup:
h2pmr wrote: Thu Mar 16, 2023 4:05 pm ... the twin filament bulb holder on the rear lamp of an 87+ that can corrode the terminals and fail can be replaced with a Peugeot 108 or Citroen C1 MK2 rear lamp bulb holder.
That's a great find!
And we do know about the corroded socket problem along with other corrosion problems. But you English would win any contest in that regard :)
:thumbup:
XR4Tim wrote: Sat Mar 18, 2023 12:37 am
h2pmr wrote: Mon Mar 20, 2023 4:16 pm:thumbup:
dafuq are those?
Anyone need a 231k-mile ‘89 motor? (Ran reasonably well when removed. Good compression. Had BS R&D Super Clamp.)
XR4Tim, javiherdepa liked this
:thumbup:
#206319
worf wrote: Mon Mar 20, 2023 4:36 pm
dafuq are those?
Quite possibly. I'm currently down to one GT engine and a few trashed blocks.
XR4Tim wrote: Sat Mar 18, 2023 12:37 am Image
I know that car, it belongs to a local P-Burg buddy, and he also has a red 84 928S (among others); he's been to Hershey with us, and that car goes. The color is gorgeous especially with the interior baseball glove brown leather.
worf wrote: Mon Mar 20, 2023 4:36 pm dafuq are those?
... picture ...
Dang. I didn't even know those existed as a part. And I thought I'd touched just about every part on a 928 at this point!
SeanR wrote: Mon Mar 20, 2023 5:19 pm
worf wrote: Mon Mar 20, 2023 4:36 pm Anyone need a 231k-mile ‘89 motor? (Ran reasonably well when removed. Good compression. Had BS R&D Super Clamp.)
Right now, it's still the property of the client. I'll be seeing him this weekend and one of the goals of that is to dispose this motor. RSN, it either needs to go away or someone needs to be on the hook for me to rebuild it. I have two clients that *should* be interested in it, but I do not have high hopes that either will be takers.
The big metal bits appear to be fine. The throttle plate cable and regulator are obviously only a couple of years old. Everything else (rubber, hoses, senders, harnesses, etc.) needs to go into the garbage. If the motor 'goes away' my intention is to have it ship in 'as is' and 'as shown' condition: all accessories except A/C compressor and hoses, no air box, etc. If one of my clients doesn't want it I'll take more pictures.
Required 928 picture and "... in other news..." : I have a plan for this. What has anyone else done?
All clear side markers installed. All have LED's. If I like how they look, I will need to wire in a resistor for the rears so as to play nice with bulb check.
See what else I started and am now pretty much committed to? After clean up, I will do some variation of the Porken Po'boy rub strip delete by filling the holes with... something.
That is a lot of work @hernanca
Mandatory 928 picture.
Reproduction of NLA 999 702 046 50. (928 Specialists has them.)
I am helping, but a buddy of mine that works with aluminum is doing most of the work. He says the Magnesium is a lot easier to work with (softer). He has a ton of tools for the work. But yes, that piece and some work on the two side plenums was all day Saturday.
Hardest stuff to get off is the old top coat that has not flaked off (beige colored). Still tackling that on the side plenums: I stuffed the plenums with paper, 3x Gorilla brand taped each large hole (intakes & balance pipe) and plugged up all remaining holes (one small threaded hole on each side plenum and one tube port on one plenum) and am media blasting it off with some nasty media. Even though everything is taped off, I will still rinse, rinse, rinse, and look inside the plenums with a boroscope.
By Don Smith
#211058
It will look nice when finished.
For me, my car is still in hibernation. There is mud and snow everywhere.
hernanca liked this
Looking good. Now we just need the rain to hold off!
By WyattsRide
#212261
linderpat wrote:Looking good. Now we just need the rain to hold off!
Either way, I'm looking forward to it!
I know you are - it has been awhile since you've been able to join in the reindeer games with your own car! This will be a good trip for it.
Bertrand Daoust liked this
That’s Gold, Sean!
k… I’ll just slip out the side door.
WyattsRide liked this
By ladybug83
#213493
By Tony
#214448
Two of the best GT touring cars ever....
RAF and Luftwaffe represent.
hernanca liked this
By WyattsRide
#215039
North Park, Pittsburgh PA
XR4Tim, linderpat liked this
#215123
In my search to fix my little ABS problem, I decided to clean the sensors.
The left back one was stuck and gave me a bit of trouble.
It didn't win!
A new one is coming from Roger...
WyattsRide, Gary Knox liked this
By WyattsRide
#215232
Bertrand Daoust wrote:In my search to fix my little ABS problem, I decided to clean the sensors.
It didn't win!
Show her who's boss my brother!!
random pictures from an SD card i found at the bottom of a draw
hernanca wrote: Fri Apr 07, 2023 10:21 pmSee what else I started and am now pretty much committed to? After clean up, I will do some variation of the Porken Po'boy rub strip delete by filling the holes with... something.
Well, it didn't clean up very well. Passenger side was worse. Paint staining and layers of paint (probably added when the aftermarket (Jacquemond?) rockers and Jacquemond rear quarters were added?).
So, back on they go (after much cleanup).
(Note: not my tools, but yes my gloves & glasses.)
amdavid wrote: Mon May 15, 2023 11:57 am Okay, which one of you are selling this beaut?.. :roflmao:
For a while there I started suspecting a sizable tear between our Universe and a parallel one where 928's never gained in value.... But this is referring to the same exact car. Perhaps its an 86.5 and they rounded up? (Nope! Antenna in the back.)
(P.S. jfk swears he knows nothing about it!)
phones have come a long way since then, but the thoughts are the same, who doesn't love pasha...
:thumbup:
hernanca liked this
My bench wasn't big enough to layout and sort all the parts. Had to do it in two batches and haven't touched the Black Cad and Nickel.
hernanca, JBT3, Gary Knox and 2 others liked this
By Don Smith
#217332
Hey guys.
My rear driver side seat back has not been working properly, since I bought the car. I had to use a screw driver to activate the mechanism. One side would unlatch, but not the other. I felt around, to find two holes, under the carpet, so I knew the problem had to be there. I pulled back the carpet, to find that one screw had dropped out of the mechanism. I found a suitable size, replaced it, and used a staple gun to re tack the carpet.
Oh, with the previous owner, we installed a Hans shifter last week, and wow, can you say, snick, snick snick?
Bertrand Daoust, worf liked this
Don Smith wrote: Wed May 24, 2023 4:59 pm Oh, with the previous owner, we installed a Hans shifter last week, and wow, can you say, snick, snick snick?
Hans Shifter Rocks
Don Smith liked this
By Don Smith
#217391
Hi Dave. Yes, that is the after photo. I only took a few photos. Not one, after we had finished. We installed mine, without removing the torque tube. Quite simply put, it was not easy. Getting to the front bracket, where we had to attach the two nuts, was a bitch...
My balls and sockets were in good shape, but the shifter was vague. Now it is amazing. Kudos to Hans.
By Charlie
#218655
Is it my age or just my 928 obsession causing @h2pmr 's avatar to make me think, "Those pod bolts are the worst." ?
Here's my newly restored interior. One cool thing: I stupidly broke my unobtainium defrost vent before reassembly but made a mold of it some time ago. So I had to use my experiment in production, and fortunately it looks and fits pretty well.
Many thanks to Worf for his constant support.
worf, Don Smith, SeanR liked this
  • 13
  • 14
  • 16
  • 17
Gary, hope all is well, and thanks for chiming in.[…]
after many years of searching finally found a set […]
There were more 928s there, but I was happy to rem[…]
My thoughts on Miami race are (I think..) simila[…]
