I think their will be clues in the vicinity of the code for the status bar and ‘place inline’ code.
If you *wait* or click-around until you see the ‘place inline’ button attachments are available.
If you attempt to submit or preview before you see the ‘place inline’ button the attachment ‘goes away.’
If this was java/java-script I would be confident that its root is a thread synchronization problem server-side coupled with poor state control on the browser side. FWIW.
The Reddit Conjecture: Sufficiently advanced stupidity is indistinguishable from malice.
Worf’s Identity: Sufficiently advanced laziness is indistinguishable from stupidity
Worf's Law: Once you've mitigated risk from stupidity and laziness in your endeavors, failure is usually the result of insufficient imagination.
My 928 Inspection Guide
