By Crumpler - Thu Sep 10, 2020 7:49 pm
#17139
In regards to a bigger pulley, I have choices, but was trying to pin down best option for 5-7 boost. I can't find an equation that get's me from impeller speed or pulley ratio (currently 2.03) and engine displacement (est 305 cubic inch/5L) to boost. Do you have an equation or link to a spreadsheet. Thanks man.
Shifted wrote: ↑Thu Sep 10, 2020 8:56 am Those seem like great numbers!Hey Chris, I was getting a bigger pulley for the blower, the 3.2 came with it. Yeah, completely different set of concerns with this build, compared to the "wyndjammer".
I once heard, and mostly agree, that performance is 90% operator and 10% equipment. But, I think that only applies when your equipment is in the same general class.
The general rule of thumb is that you double your horsepower for every atmosphere (14.7 psi) of boost. 90 hp is 30% of your NA 300hp. 30% of 14.7 psi is 4.41 psi. Really general guideline and many variables can significantly affect the outcome. But, for my car, that guideline turned out to be a close guess for my power increase.
Have you done any calculations on how much pressure your supercharger is going to produce? Because from what I'm seeing, it's going to be way over 10psi. At 6,200 rpm, you'll be spinning the supercharger at around 50k rpm with the 3.2" pulley. With our 5L motor, I would be expecting it to give you somewhere in the ballpark of 15 to 20 psi. Definitely well over 10psi. Does that jive with your own math and expectations? Maybe I'm missing something in my math :)
Devolved 86.5 Track car
Manual w/LS
DIY Supercharger
Manual w/LS
DIY Supercharger
