By SidViscous
#85905
First of I must say it's good that the tech support thread is so quiet.
Small problem I have is I seem to be subscribed to the fast pretender (Obama cuck) thread.
I would rather subscribe to hemmeroid weekly than that thread.
Well unless the pretender stuffed it and killed himself. Then I would be in there daily jerking off.
I did try subscribing and unsubscribing. No bueno
By SidViscous
#85908
Ok and now the boomers thread
SidViscous wrote: Wed Jun 16, 2021 10:17 pm Ok and now the boomers thread
So getting notifications each time someone posts on either of them?
Are you on the Flatboots or Elegance theme? Then I can troubleshoot with the right interface.
By SidViscous
#85920
Flat boots is the shitty one right.
So I'm in elegance
By SidViscous
#85921
Oh and yes. I get a truly notification when people post
SidViscous wrote: Wed Jun 16, 2021 11:24 pm Oh and yes. I get a truly notification when people post
Do you think you accidentally enabled all replies notifications?
UCP > Board preferences > Edit posting defaults > Notify me upon replies by default
This is flatboots but should be similar for you. Can you check this?
By SidViscous
#85951
I'm sure I didn't, haven't been in there b on awhile.
But I'll check
By SidViscous
#86103
In didn't see that. My options were different. There was options for getting triples from subscribed threads and such. So I turned those of SMF out send to have worked.
With around more than a fix. Buy since homey don't play the subscription game, it's good enough for me.
By SidViscous
#86305
fpena944 wrote: Wed Jun 16, 2021 11:32 pm
Okay found this now that I'm on a laptop. It is/was set to know.
SidViscous wrote: Fri Jun 18, 2021 11:34 pm
Sorry had a busy weekend - still having the same issue?
By SidViscous
#86681
I turned of those notifications. Other than that I assume it's still happening. Basically was getting notifications for every thread in the dive bar.
SidViscous wrote: Mon Jun 21, 2021 10:26 am I turned of those notifications. Other than that I assume it's still happening. Basically was getting notifications for every thread in the dive bar.
This is actually an easy fix.
Although this is flatboots you should see something similar on Elegance. But go to the "Dive Bar" main thread list and find a button that allows you to subscribe/unsubscribe from all new posts notifications. That should fix it all:
By SidViscous
#86688
Whoops, didn't see that. Didn't know you could do it for forums. Stupid fat fingers on the phone.
fpena944 liked this
All the back is done. New hard lines and SS soft l[…]
sunroof cover questions
