By Scott at Team Harco
#58894
Go to latest post feature (arrow) is not available if the last poster's name is longer than some value. Louis de Funes and my name are among the effected. I prefer not to have to start at the beginning of a thread to get to the last post.
Can this be adjusted?
#58969
OK - I see that if the thread title is clicked on, it goes to the last post. However, the date and time of the last post is truncated in many cases. This can also make it difficult to tell if you are 'caught-up'.
Just a thought starter....
#59132
fpena944 wrote: Sat Feb 13, 2021 7:36 pm I'm enjoying the city of Naples, FL this long weekend but when I return I'll look into it and see what we can do.
Are you seeing this in desktop or mobile?
Desktop. I don't like using my phone for anything other than a phone.
It turns out both of my first posts are true. If there is no option to go to a specific thread - I.e. you're already in a subforum, you can't go directly to the last post if the name of the last poster is too long.
#59156
Yossarian wrote: Sun Feb 14, 2021 11:16 am Looks to be effecting the long names, as the arrow still appears after shorter names.
You used up all the space. No arrow for you! :order:
I know. I need to shorten my name. :surrender:
This should be an easy fix. Will let my developer know and hopefully should get it fixed soon. I see it myself so pretty easy to replicate. Thanks for bringing to my attention!
Scott at Team Harco wrote: Sat Feb 13, 2021 9:21 am Go to latest post feature (arrow) is not available if the last poster's name is longer than some value. Louis de Funes and my name are among the effected. I prefer not to have to start at the beginning of a thread to get to the last post.
This should be fixed now. Can you check on your side and see if it shows up ok?
#62331
fpena944 wrote: Thu Feb 25, 2021 7:54 am
Looks good. :thumbup:
Thanks again.
fpena944 liked this
sunroof cover questions
928 quick questions thread
Sunroof t-shooting
I thought I'd post the text of the document so it […]
