By Maff
#260582
Hi
I have a radtec aftermarket radiator fitted to my 1988 S4 and the adaptor has cross threaded, does anyone know a part number or where I could buy one? Ideally in the UK but any info would be appreciated as I cant find them anywhere.
Maff
By smiffypr
#260584
The adapter between what and what?
I something is cross-threaded, I would expect two parts to be potentially damaged.
Are you looking for a 928 part or a Radtec part?
Smiffy
By smiffypr
#260585
Oh, Now the pictures appear. If it's the bit in the last picture, and it's off the original radiator, I probably have a spare. Measure the outside diameter of both threads and I'll have a look.
By Maff
#260605
It fits between the oil cooler hose and the radiator, the larger side threads have gone, they measure 24.6 mm, ive tried a hydraulic parts supplier and they say it an original thread and they cant match it.
The other side is just an M20 thread.
hi Maff
if Smiffy has not got one i think i have one somewhere.
By Maff
#260808
Thanks Smiffy
Im in Doncaster, ill send you a pm
pictures of the spacer things, i have 3 of them, 2[…]
Belly Pan Vents
