I typically browse the forum using the Brave browser on my iPhone 12. In the last week, links to videos and to Twitter simply don’t show up anymore. I do not believe I’ve made a configuration change to cause this, so I wanted to check here to see if something changed. If I use safari, I can see the links.
Brave is blocking 3rd party extensions / embeds. It’s a feature.
This is how you disable it.
@lupo.sk - thanks for the response!
@lupo.sk thank you for the pointer! Does this mean that I inadvertently turned it on because it just suddenly seemed to stop working this week.
ranger22 wrote: Wed Apr 05, 2023 12:30 pm @lupo.sk thank you for the pointer! Does this mean that I inadvertently turned it on because it just suddenly seemed to stop working this week.
Naah, brave updated some rules.
Raptor R Release (July 18)
