its NLA from Porsche.
Åke
Strosek Ultra liked this
Edit: Forgot picture…
Crumpler wrote:Image
water cooled intercooler?
Bingo Phil :)
NOS right-side parcel shelf?
Quiz:
Correct!
Mrmerlin liked this
By Rdon
#164452
Crumpler liked this
By Strosek Ultra
#168123
Åke
Strosek Ultra wrote:Image
Åke[/quote
By Strosek Ultra
#168240
Åke
Åke
By Strosek Ultra
#169507
FULL DESIGNATION: AC 35x55x20
( d ) INNER DIAMETER: 35 mm
( D ) OUTER DIAMETER: 55 mm
( B ) WIDTH: 20 mm
Åke
( B ) WIDTH: 20 mm
Åke
( B ) WIDTH: 20 mm
Åke
#170522
A 928 meet today in Montréal.
Thanks Andy!
And two very special guests!
By Strosek Ultra
#170572
Åke
Åke
#170749
Åke
lack of use in the UK
N/A to auto owners
928 Frenzy. Last Saturday.
  • 10
  • 11
  • 12
  • 13
  • 14
  • 17
Just got myself a Cayenne
Raptor R Release (July 18)
