a first attempt at a replica of a 92862404900, a protection plate that fits behind the tail gate opening motor, i guess to stop potential damage to it or the warning triangle itself when the warning triangle is removed/ refitted.
its NLA from Porsche.
genuine Porsche one on the left, mine on the right, just need to get the indentations deeper on the next one, then stick a few on ebay, should sell like hot cakes...
Strosek Ultra wrote:Think I can show this without being called a copy cat by someone.
Åke
plenty of knowledge without the ego's = a far more easy going forum in my opinion :thumbup:
Strosek Ultra liked this
innards of an in tank fuel pump
Strosek Ultra wrote: Sun Jun 19, 2022 3:06 am Think I can show this without being called a copy cat by someone.
Nice. What are you doing for a pickup tube spacer.
Edit: Forgot picture…
(Oh, BTW, if you want to post a bunch of pictures, this site’s thread navigation and pagination work better when it’s one to three pictures per post.)
Crumpler wrote:Image
water cooled intercooler?
Bingo Phil :)
It’s a small core but the only place I could get an intercooler to fit. The centrifugal SC was heat soaking badly.
XR4Tim wrote: Thu Jul 14, 2022 10:56 pm ... pic ...
NOS right-side parcel shelf?
Quiz:
no need to get the apprentice to try and make some out of a cut off bolt head, i have a few spare if you need any :thumbup:
other than that i am out of ideas :surrender:
@Rdon Your picture: $1000 of pain.
Rdon wrote: Tue Aug 02, 2022 5:09 pm “Flappy valve” stop
Correct!
Mrmerlin liked this
By Rdon
#164452
worf wrote: Thu Aug 04, 2022 7:54 pm @Rdon Your picture: $1000 of pain.
Fortunately, the pump is operational. Removed it specifically to check for a broken hose and was not disappointed. No drama with the threaded insert, replacement hose and clamps installed and now, theoretically, one less thing that could leave me on the side of the road.
Crumpler liked this
By Strosek Ultra
#168123
Things does not always go well. In this case fabricating a new wrist pin bushing is all what was needed except for a new wrist pin.
Åke
Strosek Ultra wrote:Image
Åke[/quote
interested to know more about what happened to that wrist pin
so i guess he's not perfect after all
By Strosek Ultra
#168240
h2pmr wrote: Sun Aug 28, 2022 4:42 am /\ /\ /\ /\
Nobody is perfect. I do not know how involved he was in this disaster.
You can read more here (page 7).
https://www.corner-carvers.com/forums/s ... ing-thread
Åke
Åke
thanks for the thread link, i thought it was a recent, road car engine failure but still sadly 1 less useable engine block in the world.
before i get my micrometer out, does anybody know what size bearing or generic part number of it, that fits in the A/C compressor front pulley?
compressor is the 80-89 version.
By Strosek Ultra
#169507
This bearing is a double row angular contact ball bearing. This bearing is usually used in AC compressor / compressors on vehicles, where by the additional names as AC bearing and Kompressor bearing.
FULL DESIGNATION: AC 35x55x20
( d ) INNER DIAMETER: 35 mm
( D ) OUTER DIAMETER: 55 mm
( B ) WIDTH: 20 mm
Åke
( B ) WIDTH: 20 mm
Åke
perfect, many thanks Ake :thumbup:
Strosek Ultra wrote: This bearing is a double row angular contact ball bearing. This bearing is usually used in AC compressor / compressors on vehicles, where by the additional names as AC bearing and Kompressor bearing.
( B ) WIDTH: 20 mm
Åke
sadly the 80-89 A/C compressor use a bearing 40 x 62 x 24, not quite as easy to find though
i think part number of the bearing is 40BG62020-2DLCS, will order 1 and see if it fits.
#170522
A 928 meet today in Montréal.
Thanks Andy!
A lot of fun with great owners.
And two very special guests!
By Strosek Ultra
#170572
h2pmr wrote: Sat Sep 10, 2022 1:21 pm i think part number of the bearing is 40BG62020-2DLCS, will order 1 and see if it fits.
The bearing you need is called 40BD219.
Can be found on Ebay or here https://www.bearingwholesalelots.com/40 ... on-com.htm
The bearing you mentioned is 20,6mm wide.
Åke
https://www.ebay.com/itm/192305821780?h ... BMhJDStOVg
Åke
ah yes, managed to cancel that one and get one the correct size, thank you Ake.
#170749
30 sets are ready to ship. Sorry for the wait boys and girls.
Åke
fitted the bearing yesterday and fits like a glove, many thanks.
lack of use in the UK
N/A to auto owners
more slightly unsafe corrosion
Stay in your grove you mutha!@#$ing gasket!
When you get a cam cover gasket that was rolled into a little ball for shipping:
928 Frenzy. Last Saturday.
  • 10
  • 11
  • 12
  • 13
  • 14
  • 17
What is XR4Tim Working On?
928s For Sale Thread
